Project
General
Profile
Actions
Issue #1842
open
HA
Issue #1980: Meta bug for the SIM cards not being recognized
SIM Card Not Recognised (GT-N7100)
Issue #1842: SIM Card Not Recognised (GT-N7100)
Added by Hephaestus Aitnaios about 9 years ago. Updated over 5 years ago.
Status:
New
Priority:
Normal
Assignee:
Category:
SIM card not recognized
Target version:
Start date:
11/01/2017
Due date:
% Done:
0%
Estimated time:
Resolution:
Device:
Galaxy Note 2 (GT-N7100), Galaxy Note 2 (N7100)
Grant:
Type of work:
Unknown
Description
About phone:
Device model: GT-N7100
Android version: 6.0.1
LineageOS version: replicant-6.0
LineageOS API level: Fig (6)
Android security patch level: 1 August 2017
Baseband version: Unknown
Kernel version: 3.0.101-replicant, wolfi@machinist #2, Sat Sep 9 16:01:46 UTC 2017
Build date: Sa 9. Sep 07:43:32 UTC 2017
Build number: replicant_n7100-userdebug 6.0.1 MOB31T eng.wolfi.20170909.073404
SELinux status: Enforcing.
Issue:
My SIM card is not recognised in the latest image of Replicant. My SIM card worked fine on the official Samsung ROM. I installed every single build of Replicant that is supported by my device, but none of them recognised my SIM card. I cannot install LineageOS, as the model of my device, t03g, is not supported by it.
I changed the permissions, which were wrong, to those mentioned here: https://redmine.replicant.us/issues/1800#note-6, but that did not fix the issue.
I also have the same line in my radio log as in this post: https://redmine.replicant.us/issues/1783#note-19.
Notes:
I'm running Trisquel in a virtual machine in VirtualBox. Due to issues with how VBox does USB passthrough, I cannot use adb to connect to my phone. Instead I use Android File Transfer in the host (macOS).
Files
radio-log-1.txt.gpg (16.4 KB) radio-log-1.txt.gpg Hephaestus Aitnaios, 11/01/2017 08:28 PM
efs-files.txt.gpg (1.49 KB) efs-files.txt.gpg Hephaestus Aitnaios, 11/01/2017 08:51 PM
HA Updated by Hephaestus Aitnaios about 9 years ago Actions #1
I now have full adb access via macOS.
FB Updated by Fil Bergamo almost 9 years ago Actions #2
  • Priority changed from Immediate to Normal
HA Updated by Hephaestus Aitnaios almost 9 years ago Actions #3
I solved the SIM card issue by installing another custom ROM (from the XDA Developers website) and then re-installing the latest image of Replicant.
Updated by Anonymous over 8 years ago Actions #4
Many thanks for this feedback Hephaestus. Would you kindly be able to provide us with more details on this ? Which custom ROM ?
DC Updated by Denis 'GNUtoo' Carikli about 8 years ago Actions #5
  • Category changed from Telephony and mobile data to SIM card not recognized
KH Updated by Kurtis Hanna almost 7 years ago Actions #6
  • Parent task set to #1980
DC Updated by Denis 'GNUtoo' Carikli over 5 years ago Actions #7
  • Device Galaxy Note 2 (GT-N7100) added
_R Updated by _I3^ RELATIVISM over 5 years ago Actions #8
  • Type of work Unknown added
Actions
Also available in: PDF Atom
