Project
General
Profile
Actions
Issue #2330
open
JR
Improve recovery UI
Issue #2330: Improve recovery UI
Added by John R almost 4 years ago.
Status:
New
Priority:
Normal
Assignee:
Category:
Graphics
Target version:
Start date:
01/18/2023
Due date:
% Done:
0%
Estimated time:
Resolution:
Device:
Not device specific
Grant:
Type of work:
Unknown
Description
I have installed Replicant 6.0 0004 on Galaxy S3 and on Galaxy Tab 2 10.1. The UI of the recovery mode is really bad. Some examples:
1. Extremely small fonts on huge empty spaces.
Suggestion: Increase font size and weight. Use a readable font type.
2. Anti-usability in color choice:
- red on gray (and vice versa) is a taboo in UI design. Dark blue on black is another very bad choice. This worsens readability very much.
Suggestion: Use bright color on black background.
Good UI means good contrast and easy readability.
3. Tapping on a menu is awkward. It takes the user to another menu instantly and right under one's finger tip there is another menu choice which one can easily tap and activate involuntarily. This can be dangerous, especially in a critical mode when one installs software.
Suggestion: Introduce a slight delay and visual feedback for tapping.
Note: I don't know if "download" mode can be modified but it is very bad too. I need a magnifying glass to read the text.
No data to display
Actions
Also available in: PDF Atom
